Saving bulk results on a plane as a function of time in transient analysis |
September 26, 2013, 15:40 |
CFD
Rep Power: 16 |
Hi everyone,
I am running a transient analysis and am trying to get a delta P between two planes (one near inlet and one near outlet). Is there a way to automatically save the Pressure (or any other variable for that matter) automatically at every saved time step. I have seen the Bulk tool which will give you the average values over the plane at individual time steps but there is no way of automatically saving these values as a function of time. You have to save a *.csv file individually at each time step manually. Also the Decision center seems to be for seeing the variation between the different scenarios not for variation with time in an individual scenario. thanks in advance, |
October 22, 2013, 14:25 |
Apolo
Rep Power: 16 |
One trick to getting the data (assuming you have intermediate save results):
Set your plane where you want it. Right-click and go to the animation pane Animate the results through your save intervals While animating go to the Bulk Calculator and select the quantities you want, you will be able to save the bulk results for that plane across all saved intervals into 1 csv file Repeat for any other plane |
June 23, 2015, 04:59 |
Hi everyone,
I've got exactly the same problem. After searching the internet a little I found this cool forum and even a hint on the Autodesk website (at the bottom) giving the same advice this thread. Nevertheless it doesn't work- and I'm starting to doubt myself. Propably it's one of these stupid faults.. So I would be very grateful for any help! I'm using Autodesk CFD 2016. I carry out the following steps:
I'm grateful for any help after I wasted so much time on it. |
June 23, 2015, 09:44 |
Ok, I found it out- the 2016 Version sucks!
With Autodesk CFD 2015 its working perfectly fine! |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
transient final time step results | hmasenger | CFX | 5 | September 17, 2013 11:24 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
