Home > Forums > Software User Forums > Autodesk Simulation CFD
Centrifugal Pump analysis
Old   September 8, 2015, 02:06
Default Centrifugal Pump analysis
Prabhu Prakash
daijo is on a distinguished road
Hi all,
I am doing a analysis in Centrifugal Pumps. I have done the model accordingly and followed the procedures suggested in Autodesk CF Design website. The iteration is going on solving more than 1500. But the solver is not converging.
My boundary conditions are,
Inlet pressure: 0 bar
Outlet flow rate: 4 m^3 / hr
Speed: 2880 rpm (table input: Speed - Time in seconds)
0 0 600 0.75 1500 1.5 2880 2 2880 100
No of blades 5
can you please help me in setting convergence parameters and proper input parameters.
daijo is offline   Reply With Quote
Old   October 6, 2015, 11:47
Default Centrifugal trubomachinery
AyAhSof
Sof_70_Usthb is on a distinguished road
Hi Prabhu Prakash,
I read your request of september 2015. I don't know if you've solved your problem, but for me i'm aiming to begin a research work on the tip clearence of Centrifugal turbomachines and i need a file geometry of even a centrifugal pump or compressor. It will be kind from you if you can send to me the geometry file of the centrifugal pump you're using.
Sincerly yours
A. AYOUANI
mail : aayouani@usthb.dz
Sof_70_Usthb is offline   Reply With Quote
Old   October 12, 2015, 10:56
Smile Hi, AYOUANI
Prabhu Prakash
thanks for your interest. I will mail you the model. I have tried the simulation, but i am not able to match the test datas still. I will be happy if you get 80% of the accuracy.
Old   October 16, 2015, 10:52
Default I would like to take a look at it
Isaac
isaac1326 is on a distinguished road
Hey dajjo, if you dont mind, Can you send me the model, my email id is coool5652@gmail.com
isaac1326 is offline   Reply With Quote
Old   October 16, 2015, 12:36
Default SW Flow Simulation
Prabhu Prakash
hi isaac,
thanks for your interest, i am glad to give you my model. In which software will you perform the CFD analysis and in what format do you need the files. i have the files in Solid Works 2015 format.
Old   October 16, 2015, 12:38
Isaac
I am using, Autodesk simulation 2012. You can give it to me in step format.
Old   October 16, 2015, 12:44
Default CFD analysis
Prabhu Prakash
ok issac, i will mail you within few minutes....
Thanks for your interest
autodesk cfd, centrifugal pump., pumps
Analysis of hemolysis in a centrifugal blood pump. ameen@cfd OpenFOAM Running, Solving & CFD 1 August 16, 2016 02:57
MRF analysis for centrifugal pump Selvaa FLUENT 1 February 19, 2015 07:47
3d centrifugal pump analysis in fluent_turbo manuvel FLUENT 0 May 4, 2012 02:54
CFD analysis of centrifugal pump saurabh9978 FLUENT 1 April 6, 2010 05:40
CFD analysis of centrifugal pump saurabh9978 FLUENT 0 March 21, 2010 12:07
