Home > Forums > Software User Forums > Autodesk Simulation CFD
Inside pipe wall temperature rise time t=?
Old   September 2, 2017, 04:24
Default Inside pipe wall temperature rise time t=?
tibor
tibor is on a distinguished road
At time t=0 both the inside and outside temperature of pipe is at 21.1 degc (no fluids inside the pipe).
At time t=? , fluid flows inside the pipe carrying 427 deg c at velocity V.
My question is during the contact of fluid to inside wall pipe, will the inside wall temperature of the pipe will abruptly change from 21.2 deg C to 427 deg C ) Say at 1 sec?
Or is it gradual say 60 sec?
Can we run CFD to obtain this rise time inside the wall of pipe temperature? In case can run, what are data needed ,etc.?
Thanks a lot in advance ..
Or
tibor is offline   Reply With Quote
Old   September 2, 2017, 10:27
Jon Wilde
W!ldejon is on a distinguished road
It would change over time until everything reached the same temperature as the incoming fluid.
Could you keep it simple and start with the pipe full of fluid?
Set initial conditions to all volumes and run transiently, shouldn't take long
W!ldejon is offline   Reply With Quote
Old   September 2, 2017, 21:54
tibor
Thanks for the info.. CFD Analysis is required in this face. Do you know some work around to estimate the heat transfer coefficient W/m^2-K of an incoming fluid at say 427 deg C and velocity V.
Sent from my iPhone using CFD Online Forum mobile app
Old   September 17, 2017, 09:26
tibor
I already found how to calculate HTC using Ansys Fluent. My next question is "Is HTC time varying also"?.If yes , how to extract in Ansys Fluent?.Many thanks
Old   September 22, 2017, 10:59
tibor
We are all in the same page in this case
Old   September 22, 2017, 17:50
tibor
I finally found the answer.. it's only an average value.,
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 10:54
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
