March 27, 2018, 14:08 |
Volume FLow Rate as a Result
Adrian
for the inlets and outlets, i can chose for the boundary conditions, pressure, velocity, volume flow rate, etc. but i can not see the volume flow rate as a result. i have a pipe, and i just want wo know what flow rate i have at the end of the pipe depending on the incoming pressure. i could calculate the flow rate i i have the avarage speed of the fluid at the end of the pipe. how can i see results as a avarage speed, or flow rate ? thx. |
January 31, 2019, 12:51 |
Sam Bush
1. define results plane that intersects with your pipe of interest
2. under the planes stab, use the "bulk calculator" - flow is one of the output options |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
volume flow rate for outlet boundry condition and dfine udf for it | raminostadi | FLUENT | 0 | December 24, 2016 01:52 |
Volume flow rate through actuator disk (Tidal turbine) | egge24 | FLUENT | 4 | August 12, 2013 15:18 |
how to calculate the reversed volume flow rate in an certain iso-surface? | coolliuyinli | FLUENT | 2 | September 4, 2012 01:33 |
Volume of Flow Rate (VFR) boundary condition | therockyy | FLOW-3D | 0 | May 23, 2011 14:19 |
