April 16, 2024, 07:36 |
Problem in indoor gas diffusion simulation
Hello guys !
Since my English skills are poor, I am writing using a translator. Please understand if there are any rude or slightly incorrect expressions. I am asking this question because I would like to run a simulation to see how carbon monoxide spreads in an enclosed space. I want to simulate carbon monoxide being injected into the internal space through the inlet. If I set the internal space to air and the inlet part to CO and then set the volumetric flow rate in the boundary conditions, a message appears saying that separate settings are needed because the two fluids are different. How should I set the boundary conditions to simulate how carbon monoxide spreads into the internal space through the inlet? This is a situation where CO enters the internal space from the inlet at the bottom. uploading modeling photos together. Thank you for reading my post ! |
Soot simulation in a laminar diffusion C2H4 flame | duanwuCHEN | FLUENT | 0 | February 8, 2023 20:50 |
ion & electron diffusion - how to proceed/improve simulation? | shinigamirem | OpenFOAM Programming & Development | 0 | July 17, 2020 09:26 |
Dynamic mesh simulation (pimpleDyMFoam) problem | sidlof | OpenFOAM Running, Solving & CFD | 6 | April 12, 2013 11:24 |
Large-scale simulation problem | Purushothama | Main CFD Forum | 0 | November 7, 2010 20:12 |
Time unit in finite volume solution for diffusion problem. | alpha2beta | Main CFD Forum | 0 | June 30, 2010 02:05 |
