Home > Forums > Software User Forums > AVL FIRE
formula
Old   November 11, 2012, 17:04
Default formula
reza hemmat
rezahemmat1985 is on a distinguished road
hello,
I wanna to simulate single-phase boiling in a duct via AVL Fire. I need to compute the contours of {htc(boil)+htc(convective)}. but unfortunaltely I canot do anything to compute the mentioned sum. I have heared it can be done by wrting a formula in Fire 3D plot but I canot. some one said to sum those htc in Tecplot! does any one have any idea? if yes lease tell me the procedure.Any comment is appreciated. Thanks in advance.
hint: htc(boil) and htc(convective) contours both are computed seperately.
rezahemmat1985 is offline   Reply With Quote
Old   November 22, 2012, 05:40
Default °
Arno Nymus
cschm is on a distinguished road
Hi rezahemmat1985,
there you have essentially two ways to produce this post-processing. If you're on v2010 or later, you can put the formula into $HOME/.avl/avl\ fire\ wm/2011/derivedQuantities. It is then applied online, no need to read your data and write the results into you 3D-Results.
If you're pre-v2010, you need to write the data into your fl3-result-file using the cfdDerive command line tool. Just look into the workflow-managers manual to learn about it's usage.
If you want to see example formulas you can look into your install dir: $AVLAST_HOME/CFDWM/v2011.1/files/formulaExamples/AK_AttributeFormulas/cfdDerive/
There you can see a lot of examples how to postprocess the results. In essence, there are three steps:
Use the Bind() command to get the two HTC values
use strcpy(name, "ElementData:Flow:CombinedHTC:W/m^2"); to export the new values name
In the formula body, just return the two bound values.
HTH
cschm
cschm is offline   Reply With Quote
doubts on the formula of near-bed concentration in volume superhugo Main CFD Forum 1 April 27, 2012 02:28
janafThermo: How to read formula? or at least: How to use hPolynomialThermo? bgoeppner OpenFOAM 0 February 22, 2010 15:17
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
how to define pressure drop formula in a pipe Yessica Pomarinni FLUENT 2 August 31, 2007 11:09
Benetton Formula 1 CD adapco Group Marketing Siemens 13 February 7, 2002 09:33
