April 8, 2013, 22:47 |
Injection Rate
Joshua
I want to ask how do I calculate the injection rate in the spray module if i know the amount I wanna inject and also the injection pressure? Say i need to inject 2mg of diesel at a injection pressure of 40MPa what would be the injection rate? |
April 11, 2013, 01:19 |
Myunghwan Kim
Hi JoshS,
There is no special way to get the appropriate injection rate. Injection rate should be a result from many factors. - whole FIE system, injector mechanism, injection pressure, duration, nozzle shape, environment condition.. Normally, this is measured in special device or simulated with FIE simulation tool like as HYDSIM or AMESIM. Otherwise, you may take a injection rate diagram from paper/reference with similar injector/condition. |
April 11, 2013, 22:33 |
Joshua
Hi, kimmhw
In fire, the mass in computational domain under injected mass, why does it not equal to the total mass injected? and is there any place I can set the injection pressure? |
April 11, 2013, 23:00 |
Myunghwan Kim
Hi, JoshS,
There is no input area for injection pressure. As I told, the injection pressure is not an input in case of 3D spray/combustion simulation. Regarding the difference between target mass and actual injected mass, I have no idea. It should be same after end of injection. |
May 10, 2013, 22:24 |
Spray Modelling
Rouzbeh Nejatbakhsh
I have some problems in modelling sprays in part load in internal combustion engines
if possible for any one help me about this issue I work in AVL FIRE buti dont know which parameters i should change in sub model please help me |
May 11, 2013, 01:03 |
Myunghwan Kim
Hi rouzbehnejatbakhsh,
You should describe your problem in detail. Gasoline?Diesel? Operating point Which breakup model / combustion model is used? How different between FIRE and measurement? Others. Actually, there are so many factors which affect to simulation results. |
May 11, 2013, 03:44 |
#7 | |
Rouzbeh Nejatbakhsh
the main topic is this: numerical study on the hydro dynamics behavior os fuel spray in part load operating conditions by part load we mean 2500 to 3500 rpm and we prefer diesel we dont consider combustin and just the specifictions of spray are importent for me Iuntil now I cant finf any expermental article on this topic if it is possible for you help me more! |
May 11, 2013, 03:49 |
#8 | |
Rouzbeh Nejatbakhsh
and some information about fuel injectors too!thanks! |
May 14, 2013, 20:37 |
Myunghwan Kim
Hi Rouzbehnejatbakhsh,
Frankly, I cannot understand what you mentioned "numerical study on the hydrodynamics behavior of fuel spray" Regarding part/full load condition, well.. air mass, wall temp., injected mass/timing/rate will be changed. If you have no previous experiences, please start with primer and example. |
May 30, 2013, 08:20 |
#10 | |
Rouzbeh Nejatbakhsh
I mean by hydrodynamic that the behavior of spray without considerations of combustion and just the cfd modeling of spray and the SMD and PENTRATION AND OTHER spray important specification in AVL FIRE SOFTWARE PLEASE HELP ME MORE ON THIS ISSUE |
December 30, 2014, 13:59 |
#11 |
sina
hi , how can i import Injection Rate Diagram ?
March 5, 2015, 03:28 |
importing injection rate
#12 |
Rakesh
Rep Power: 11 |
u can import in the form of table...i.e.
crank angle vs quantity to be injected.. |
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 09:58 |
Dpm injection mass flow rate | diamondx | FLUENT | 0 | November 22, 2012 13:04 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 11:12 |
Group Injection Flow Rate | Mr. CFD | ANSYS | 0 | January 25, 2012 10:34 |
Variable mass flow rate injection. | Eng_mech78 | FLUENT | 0 | April 4, 2011 11:49 |
