Home > Forums > Software User Forums > AVL FIRE
AVLFire EseDiesel-mesh cannot be created
Like Tree2Likes
  • 1 Post By amin_u50
Old   January 29, 2014, 19:09
Default AVLFire EseDiesel-mesh cannot be created
EMRE
noname1905 is on a distinguished road
Hi firends,
I am trying to learn avlfire-diesel for senior design project.
İf i want to generate 2D mesh, an error occured.
Mesh can not be created.Average cell size is too big.Although i reduce average cell size , same error occured.Thanks for your help.
noname1905 is offline   Reply With Quote
Old   January 30, 2014, 15:07
amin u3fi
amin_u50 is on a distinguished road
Hi....
You should change your block structure. If you set a correct block you can generate 2D mesh
amin_u50 is offline   Reply With Quote
Old   January 30, 2014, 16:44
EMRE
I am looking application example.Where i am making mistake?
Old   January 31, 2014, 02:00
amin u3fi
Hi...
oh... u make a clear mistake. Your structure (line structure) should not intersect each other.
best regards
Amin_u50
noname1905 likes this.
Old   January 31, 2014, 02:56
EMRE
Thanks a lot.when i change values to avoid intersect , i can create meshes.
Old   January 31, 2014, 04:13
EMRE
This time i can create meshes but i can not save.
2D meshes have overlapped region.İt is not possible to save CFDWM project.Create 2D meshes with different cell size.
Old   January 31, 2014, 05:14
amin u3fi
I didn't understand what's your problem? plz explain your problem clearly
Old   February 3, 2014, 06:43
EMRE
I need to save in order to start simulation.But if I want to save programme an error occured.
Old   February 3, 2014, 10:21
amin u3fi
You have over lapped regions it means that in 3D meshes you gain negative volume and it's false. You should change your mesh structure with block structure and try the best.
Best regards.
Amin_u50
Old   February 12, 2014, 08:17
EMRE
I know fourstroke engine have 4 step:
0-180Cad İntake
180-360Cad compression
360-540Cad power
540-720Cad exhaust
But it does not same in avl.How these step are classified in AVL?
Old   August 16, 2014, 11:16
ABDUL GAFOOR CP
gafoorcp is on a distinguished road
hiii...
As i understood about ur question,
in ese diesel they started their simulation for the second cycle of a cylinder...that means...the TDC after compression will come at 720CAD....so u have to convert your valve events according to that...
take 360 as ur 0 CAD position..then continue.....
please reply if u got my point....
regards...gafoor
gafoorcp is offline   Reply With Quote
[ICEM] Hole is created while decreasing mesh size cbaraj ANSYS Meshing & Geometry 1 October 29, 2013 12:32
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Left handed faces created by adaptive mesh RagingPotato FLUENT 0 April 3, 2012 12:29
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
