Home > Forums > Software User Forums > AVL FIRE
AVL start problem :MPI issue
Old   September 13, 2014, 04:35
Post AVL start problem :MPI issue
ABDUL GAFOOR CP
gafoorcp is on a distinguished road
I am facing the problem to run the setup with more than one MPI at a time. This problem is only for some setup and all other setups are running in multi mode in the same computer.But the same setup which is not able to run in multi mode in PCs( all 4 nos. spec: 2GB ram DDR3 1066GHz) is able to run in a workstation with high configuration.
i have faced this problem when i was trying to run an already completed solution by save as option into change some parameter. After several tries, i made it to run by loading the same file into a new folder and restarting the setup by editing the required parameters. but still i couldn't run the solution in two computers.
So please suggest me the possible reasons for this problem...
with regards
gafoor
gafoorcp is offline   Reply With Quote
Old   June 21, 2022, 02:27
Richard
vivirichard007 is on a distinguished road
with regards
gafoor
Hi Gafoorcp, I'm also facing the same issue. Models are running fine in workstation. But, when running on multi-node simulation doesnot start. If you found any solution can you please share?
Thanks.
vivirichard007 is offline   Reply With Quote
avl fire, cfd, mpi
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
Problem in parallel Fluent under Ubuntu (loading MPI?) Alucard FLUENT 2 October 22, 2013 16:37
Multi-region MPI parallel issue psosnows OpenFOAM Running, Solving & CFD 0 June 29, 2011 15:46
problem in runggin MPI example RK Main CFD Forum 1 July 22, 2005 22:25
PROBLEM IN PARALLEL PROGRAMMING WITH MPI Niavarani Main CFD Forum 1 April 20, 2004 06:51
