Home > Forums > Software User Forums > AVL FIRE
Facing Divergence when trying to inject methane through a separate port into a piston
Prev Previous Post   Next Post Next
Old   March 2, 2017, 10:40
Default Facing Divergence when trying to inject methane through a separate port into a piston
Rahul Surianarayanan
Rahul_Surya is on a distinguished road
Hi guys,
So I'm trying to run a dual fuel case where I created a separate port on the piston head as an inlet for methane gas. The length and diameter of the cylindrical port is 5mm X 2mm. The aim is to inject methane gas at about 40 CABTDC and spray n-heptane at about 15 CABTDC. At first I faced divergence when I setup both the intake port for methane and nozzle for n-heptane. Therefore I tried to test the port and the nozzle separately. By doing so the methane gets injected through the port and crashes at 150 CABBTDC. Same for n-heptane, it crashes after the spray and combustion at 150 CABBTDC. I get the same error for both the cases which is
ArbitraryFaces, 1022:bad coordinates of vertex 20721 in cell 15047:-1.#IND -1.#IND -1.#IND
This is an error that I have never faced before. In fact I used the same geometry to run many other cases without the port and it runs just fine. It seems as if the port and its arbitrary connection is creating an issue. But I examined those cells and they all look normal.
Any help will be greatly appreciated. Pls feel free to ask me more details if needed. Thanks
Rahul_Surya is offline   Reply With Quote
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 12:31
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
