Home > Forums > Software User Forums > AVL FIRE
3d Simulation of Oil droplet in water without touching walls
Old   November 14, 2017, 02:52
Default 3d Simulation of Oil droplet in water without touching walls
Nastaran
Nartasan is on a distinguished road
Hi all,
I'm trying to simulate an oil droplet in a microscale water tube without touching the walls in the meantime. My sim is based on Multiphase/VoF model and need to use csf model in solver. I'm using AVL Fire and now have some issues and questions:
1. when I active the csf option and put the correct values of "contact angle" and "Surface tension coefficient" my runs diverge. while the simulation goes pretty well when I don't activate csf option.
2. I know that contact angle define when there is a wall with a normal vector on the surface of the oil(in this case), but what if I don't have any contact with wall right now....should I assume only an imaginary parallel wall with real wall and find the contact angle based on that? or I should only use two fluids model and not vof?
3. if I want to define the surface tension as an output variable for checking its values over time, should I use csf method and assume surface tension as a body force and then right e new subroutines?
Could you please help me I'm new in this field.
Nartasan is offline   Reply With Quote
Solid object falling in water tank simulation cassini83 CFX 3 August 9, 2021 17:05
How to patch a water droplet with smooth surface? Hossein1 FLUENT 0 January 13, 2017 09:25
Water Injection + waves for in an oil tube Ahmed Alaa Fluent Multiphase 0 June 13, 2015 04:44
Simulation Water and Oil URGENT problem alexandrelp CFX 3 May 5, 2014 21:20
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
