December 26, 2000, 07:44 |
Computation of Lift and Drag
For a subsonic external flow of an object of length L, what could the suggested computational domain to capture the velocity and flow profiles well.
The inlet I thought we could define thru' velocity and outlet thru pressure conditions. Is it OK. What is the suggested approach to compute the lift, drag, moment coefficients, Xcp in STAR-CD code |
December 27, 2000, 03:25 |
Re: Computation of Lift and Drag
1.You can use POSDAT.f to edit what you want. 2.The variable FORCB(I,IB) OF POSDAT.f is the global force at boundaries IB.And the index I is: I=1,X-dir I=2,Y-dir I=3,Z-dir
drag coefficient computation on a porous jump??? | Fabrice | FLUENT | 4 | June 5, 2017 05:30 |
Drag computation in 141 | aunola | OpenFOAM Running, Solving & CFD | 20 | March 18, 2009 05:37 |
drag computation on LS-DYNA | Francis | Main CFD Forum | 0 | February 2, 2009 04:11 |
Drag force computation | Martin | Main CFD Forum | 9 | July 11, 2008 09:10 |
Lift and Drag | Pedro Lopes | CFX | 1 | February 19, 2007 08:18 |
