Help in Loading STARHPC on SGI Origin 2800
Old   December 13, 2001, 01:48
Default Help in Loading STARHPC on SGI Origin 2800
anindya
I need help in loading the parallel (STARHPC) version of starCD on a SGI Origin 200 machine. I need help in setting up the environment using ProHpc.
Thanks
Anindya
Old   December 13, 2001, 13:04
Default Re: Help in Loading STARHPC on SGI Origin 2800
Joern Beilke
Get the "mpi" and "array" software from the sgi page, install them and type "/etc/chkconfig arrayd on" . Then either start the array deamon manually or reboot the machine. Nothing more should be required.
There also exists a very nice description about HPC on SGI written by Ayad Jassim, but for some strange reason this document was never provided with the installation.
Old   December 13, 2001, 13:22
Anindya
How can I get hold of the documentation by Ayad Jassim?
Anindya
Old   December 13, 2001, 17:46
Joern Beilke
You might ask the support people in London. Since you do not post your email I cant send you the file.
Old   December 13, 2001, 18:43
Anindya
Please send me the file if you have it. My email is anindya@iastate.edu .
Thanks
Stl from SolidWorks getting the origin right sjs OpenFOAM Pre-Processing 2 July 23, 2008 15:43
where is the origin of a boundary face for udf ma jie FLUENT 1 August 14, 2006 15:21
submit a job on the SGI Origin 3800 Jason FLUENT 0 February 28, 2005 22:30
Coordinate of axis origin Tang FLUENT 0 October 4, 2004 16:38
How to use all the memory in SGI Origin 2000 G.P. Xia Main CFD Forum 3 April 24, 1999 11:23
