Pressure distribution
Old   December 7, 2001, 04:01
Default Pressure distribution
Lennart Wern
Hi evereybody
I am interested in studying pressure distribution on different objects. Is there anyone that know which turbulence model, differencing scheme and solution algorithm is best to use? The K-E model seemes to overpredict the pressure at the stagnation point a lot.
I am also interested in studying the frequency of the von Karman's vortex street in transient analysis. Is there anyone that know which turbulence model, differencing scheme and solution algorithm is best to use in this case?
Regards
Lennart
Old   December 7, 2001, 05:41
Default Re: Pressure distribution
john
It seems that the best combination is: cubic k-e turbulence model (especially the lower Reynolds number version if you can afford the mesh density near wall) and MARS scheme for convection term discretisation. The solution algorithm should not afttect converged results. The v2f model is very good - but you have to pay for it since it's an external model from Standford.
CD should be able to send you its case of flow pass the square cylinder with von Karman vortex. It seems K-e model is good enough to do it with above 95% blending between Centeral and upwind schemes. But you have to have reasonable mesh density around the obstacle to resolve the vertex. Also set your upstream boundary (inlet?) far enough from the obstacle with proper profile of boundary condition.
Old   December 11, 2001, 08:46
Lennart Wern
Hi John
Thank you for your answer.
I have tested different turbulence models (heigh Reynolds only) and MARS. I have compared the Cp-factor at the stagnation point. As I think you know
Cp = (P-Pref) / (½·Rho·U·U)
Theoretically it should be 1.0 at the stagnation point. My little test givs that the RNG turbulence model gives the best result. It was also much easier to get STAR to converge with RNG than "Cubic Heigh Reynolds". Wth the standard K-E model I got the highest (=worst) values.
Have you compared the pressure calculated with STAR with measurements?
pressure distribution sometime1990 CFX 1 November 13, 2008 08:08
Pressure distribution along hull sam CFX 1 September 13, 2008 17:09
Pressure distribution DAK565656 CFX 4 September 21, 2005 08:20
Pressure distribution Sham FLUENT 3 August 23, 2005 01:16
Pressure distribution Achilleas Tsompanos Main CFD Forum 0 March 7, 2000 10:50
