Convergence
Old   March 1, 2002, 08:35
Default Convergence
andrea
I have some problems because the residuals oscillate around an average value . I have decreased relaxation factors of velocities and pressure. What else can i do?
Andrea
Old   March 6, 2002, 10:33
Default Re: Convergence
Jing
Please check if it is a unsteady flowfield. If it is, it is normal the residuals oscillate around an average value when you calculte it as a steady flow field.
Old   March 6, 2002, 11:21
Andrea
It's a steady flow field. Anyway thank you for the answer.
Andrea
Old   March 6, 2002, 22:17
john
Jing's response is quite possible. Several things may also be considered: 1. relax. factor for p is not small enough, have you tried <0.1 2. mesh is too fine, or bad quality, 3. wide open pressure boundary 4. you are too picky, the solution is good enough
Old   March 7, 2002, 10:50
andrea
Thank you for your answer,first. I can't understand what' s the meaning of "wide open pressure boundary": in our model we define a pressure boundary to simulate the flow exit in the open air (environment pressure); it takes quite a big area: do you think this could create problems? Why?
Andrea
Old   March 9, 2002, 00:33
john
Depend on how big and if inflow is induced at pressure boundary, and how stable this inflow is. Basically, when solving Navier Stoke eq. pressure boundary is not required, but velocity boundary is necessary. For some reasons, they allow you to define pressure boundary but internally still velocity to be applied at the pressure boundary, and mostlikely it is velocity gradient. When pressure boundary is used, and if you did not provide velocity boundary at other boundary as a stronger reference, how flow knows where it should go. Then, it get lost or get to endless solutions. Check if your flow pattern is stable, and if inflow occured, check it closely.
URF and convergence in natural convergence Marie-Anne Main CFD Forum 11 September 11, 2009 10:07
convergence vijay FLUENT 6 February 1, 2006 03:04
convergence vijay Main CFD Forum 1 January 30, 2006 13:13
too bad convergence Davoche Main CFD Forum 2 November 20, 2005 05:08
About convergence LQ CFX 3 June 2, 2005 23:43
