Tutorial
Old   May 17, 2002, 13:04
Default Tutorial
torsani
Hi, I'm beginner user of Star-CD. I modeled the Tutorial 7.3 but I didn't undestand the procedure for run this analysis. The commands pmovlink and starlink didn't run. Please, what procedure should be executed for this analysis? Thanks
Old   May 20, 2002, 13:09
Default Re: Tutorial
Jamie
pmovlink is used for an analysis using moving mesh events. You need to use pmovlink for this tutorial. Did you get some kind of error message?
Old   May 20, 2002, 13:33
torsani
I don't know where I should type the pmovlink command: in the prostar prompt, in DOS prompt or other place. In prostar prompt this command return:"**UNRECOGNIZED COMMAND - (PMOV)ENTER A COMMAND OR HELP OR EXIT" In DOS prompt this command wasn't found.
Old   May 21, 2002, 03:13
HVN
The tutorials are taylored to be used in Unix or Linux. For these OS, you need to type the command in the unix/linux prompt.
For Windows, you need to go to Solve option on your Star-CD launcher and click on Moving grid case option.
HV
---------Tutorial help mech FLUENT 4 May 16, 2007 02:43
tutorial 6 in Fluent 6.2 tutorial and Mesh pilli4u FLUENT 2 April 2, 2007 05:09
3D Tutorial MJ FLUENT 0 January 16, 2007 08:45
tutorial masood yooceframandi FLUENT 1 January 25, 2005 12:28
tutorial adil FLUENT 0 March 8, 2004 03:48
