May 2, 2002, 05:34 |
Simulation of a four stroke engine cycle
My requirement is to simulate events in a four stroke diesel engine, i.e, a 720 degree cycle simulation. So the methodology I adopted to set up the events module is to modify the events given in Prostar tutorial no.13 to simulate all the four strokes. The only error I get is that, by the usage of EVPARM,PISTON,..command for defining the cylinder mesh events over 0 to 720 degrees, I get a duplication of event times for degrees after 360 degrees crank angle,i.e, the event times again start from 0.0 after 360 degeee, resulting in un-uniqueness of event times. Iam in requirement of a solution to the problem.
Regards, Alfred Herman. |
May 27, 2002, 07:05 |
Re: Simulation of a four stroke engine cycle
I've had the same problem The only solution i could get is to use a spline defining piston postion and then not use the piston option but evparm degrees, simular to calculating valve positions.
two stroke engine | ali | FLUENT | 0 | January 6, 2009 04:00 |
2-stroke engine combustion | A Student | Siemens | 5 | June 1, 2006 12:16 |
2-stroke engine | A Student | Siemens | 2 | May 19, 2006 00:36 |
problem:case331,two stroke loop scavenge cycle 3D | lee ho boon | Phoenics | 1 | April 24, 2002 11:14 |
2-cycle engine modeling | Roy Perryman | Main CFD Forum | 4 | October 16, 2001 05:37 |
