multicomponent mixing...
Old   May 14, 2002, 09:35
Default multicomponent mixing...
july
Hi... my problem involve multicomponent mixing... i've two species H2, Air, they flows in separeted channel but they comunicate by a porous media... i've obtained a solution but there are many warnings in the file.inf
iteration number 1 1)warning 042 2)warning 044 3)warning 009 (the value of scalar sc2 in cell ...is below the minimum.... any advise for this kind of problem...?
Old   May 16, 2002, 23:20
Default Re: multicomponent mixing...
raymond
It only display in iteration 1, for your initial condition of calculated component is too lower. It's nothing important.
Old   May 19, 2002, 22:38
John
Scalar transports by convection and diffusion. Either steady state or transient, convection effect only goes several cell layers in each iteration or time step depending on velocity. But diffusion equation is implicit, and any disturbance should spread out instantly to the whole field. If it is far away from source, the concentration should be nearly zero, and thus give a below the minimum value. In steady state SIMPLE algorithm, this should disappear after some iterations; otherwise, check mesh quality. And similarily, in transient process.
Multicomponent mixing Sam Siemens 0 February 9, 2006 11:37
How to do this multicomponent flow in cfx? John CFX 0 February 4, 2006 10:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Multicomponent Carola CFX 1 September 2, 2003 16:03
ideal gas mixing law and mass-weighted mixing law Shankar FLUENT 0 June 24, 2003 13:25
