Informatio transfer between models
Old   December 8, 2002, 01:45
Default Informatio transfer between models
Julie Polyakh
Is it possible to transfer geometry and droplets properties from one case to another?
Regards,
Julie
Old   December 8, 2002, 01:46
Default Information transfer between models
Julie Polyakh
Old   December 9, 2002, 05:18
Default Re: Information transfer between models
support
You can use the facility of saving the mdl file info as cel, vertex, inp files etc. For example to save local.cel, local.vrt etc, you can use the PROSTAR command, cdsave,local.cel,local.vrt,local.bnd,local.inp,-1
why don't you try to import the inp file
Old   December 9, 2002, 20:38
CJ Tune
I think it'll be simpler to just copy the .mdl file and then do modifications from ProSTAR on it (assuming the new model is similar to your old one). CDSAVE was meant to make it possible to transfer geometric and setup data to other systems that your current binary files are incompatible with but frankly I haven't used it for that reason yet. I run STAR-CD under Windows, Linux, HP-UX, and IRIX.
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 03:21
Conjugate heat transfer models Alex Phoenics 8 April 6, 2009 15:58
Heat Transfer in Multiphase Models (Star CCM+) Luke Treadwell Siemens 2 September 7, 2008 20:14
low-re models and heat transfer coefficient Massimo Main CFD Forum 5 December 22, 2005 02:57
CFD models Xie Main CFD Forum 0 April 18, 2002 13:48
