December 22, 2002, 12:25 |
Total heat through a wall
Hello. I have a problem with the Heat_Flux trough a wall; I have red the chapter 9 of methodology guide but I can 't understood the meaning of Heat_flux that is showed at get wall data menu. Which of the two possible case the function "heat_Flux" rappresents?
First case: the Heat Flux rappresents total Heat flux trough the wall than 1) Heat Flux = TIRA - TRAD - Heat Convection (only convection and radiation) Second case: the Heat_Flux rappresents only convection Heat(and conduction if presents) than 2) Total Heat = TIRA - TRAD - Heat Flux (only convection and radiation) |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 03:27 |
Total Heat Flux Calculated by FLUENT | Darron | FLUENT | 5 | November 16, 2010 21:17 |
Total heat flux vs surface integral | Al | FLUENT | 0 | December 22, 2008 12:16 |
Inconsistent Total Heat Transfer Rate | Ken Adams | FLUENT | 0 | July 24, 2007 11:04 |
Help! Total heat transfer rate doesn´t sum to zero | Thomas | FLUENT | 0 | April 6, 2005 02:55 |
