WALL FUNCTION
Old   February 14, 2003, 06:29
Default WALL FUNCTION
tomosada
1. How can I change the y+ of wall function ?? should i modify the subroutine "modswf.f" ?? If yes, how do i modify it ??
2. Did any body have used two-layer , where can i found the tutorial of the mode ??
Thank you for answer me!!
Old   February 14, 2003, 10:48
Default Re: WALL FUNCTION
cjtune
I can't help on Q#1 but for Q#2, you have to turn on and choose one two-layer model in the 'turbulence models' tab, and turn on the 'Two-layer' option to 'Active' for the walls you want to use the model on. You can leave the other walls as normal (Two Layer = inactive) to use the 'regular' wall-function models on them to save time on calculations (eg. on areas of less interest).
How can I add a new wall function imano OpenFOAM Running, Solving & CFD 14 September 17, 2015 08:53
Bug in wall function rolando OpenFOAM Bugs 7 June 8, 2007 04:51
wall function Alex CFX 9 May 19, 2005 10:05
Does RSM use wall function? Sam Main CFD Forum 4 March 2, 2005 23:58
Wall function Min-Hua Wang CFX 4 July 5, 2002 12:13
