September 21, 2003, 03:07 |
Erosion problem
Dear All,
Is there anyone who has the experience in simulating erosion problem by using STAR_CD? I have done all the jobs, including calculating the two-phase flow and use the subroutines for erosion model as well as rebound model to calculated the erosion. But when I finished all of the procedures, all the data of erosion rate, erosion ratio, impact velocity and impact angle are zeros. Can anyone tell me what happened? Ko |
September 24, 2003, 05:47 |
Re: Erosion problem
In the 15th issue of Star-CD newsletter there was a small article on errosion modelling. It was done by Wood Group Pressure Control Ltd, you can try to contact them.
September 24, 2003, 07:48 |
Re: Erosion problem
Sometimes, this indicates that you have some problems with the particule trajectory calculation. Do you check that all particules exit the fluid domain.
EROSION UDF | shehab abdelrahman | FLUENT | 1 | February 12, 2008 05:15 |
Pipe bend erosion problem | John Yang | FLUENT | 2 | December 12, 2007 04:06 |
about erosion problem caused by solid particles | hannah | CFX | 4 | August 20, 2003 04:42 |
Erosion | David Connolly | Phoenics | 1 | June 24, 2002 06:16 |
