October 27, 2003, 18:41 |
blower with sliding mesh
I am doing blower simulation with sliding mesh. The output residual seems not right ( -1 order of magnitude). The mesh is pretty coarse, about 100 circumferentially. After 6 cycles of spin, the residuals are still fluctuating about. Is that normal? Can someone give me a clue. Thanks in advance.
October 29, 2003, 23:37 |
Re: blower with sliding mesh
For transient simulation, the output is NOT residual: it's rate of change in time. So probably your solution is OK.
November 5, 2003, 07:22 |
If it is 'rate of change'. You can still check residual levels by changing 'rate' switch in Analysis Control->Output Control->Monitor Numeric Behavoir to 'residual'. Then see whether is really wrong or not.
November 7, 2003, 00:13 |
Thank you all for advice. Very helpful.
what does sliding mesh REALLY mean? | Jason | FLUENT | 2 | February 21, 2012 05:49 |
UDF or Sliding Mesh? | Chris | FLUENT | 1 | April 22, 2008 10:43 |
sliding mesh | sulfi | FLUENT | 3 | April 27, 2005 06:55 |
Sliding Mesh | Sridhar | FLUENT | 0 | August 23, 2002 14:54 |
Sliding mesh | Dimitri | FLUENT | 1 | July 30, 2002 04:41 |
