refine issue
Old   December 19, 2003, 06:28
Default refine issue
judy
I am refining some quad(shell) cells. The problem is some cells getting refined in i directing and some in j direction in a single command when executed for only one (say i) direction. I am using cref command. How this is happenig? Anybody has faced this problem before? Kindly guide. Thanks.
Old   December 20, 2003, 09:03
Default Re: refine issue
4xF
Quad shells are defined by 4 nodes, 1, 2, 3 and 4 counted in counterclokwise order. Direction 1 -> 2 corresponds to direction i, direction 1 -> 4 corresponds to direction j. So depending on the shell definition, i.e . the direction i of one shell will be the direction j of other shells.
Old   December 22, 2003, 00:53
judy
Thanks a lot 4xF. But how to sort out this issue? Please guide.
Old   December 22, 2003, 04:32
HVN
You need to reorder your I,J,K directions as I remember with the command CDIRECTION before using CREF.
There is a useful command that allows you to visualize the direction but I don't remember the name. Ask to your support office.
HV
Old   December 22, 2003, 06:47
roadracer
Try with creorder.
Old   December 22, 2003, 23:48
judy
Thanks to all for spending your time
Old   January 4, 2004, 02:36
azmir
Hello! DId u resolve your problem? I had a headache on this matter myself. I think there should be a more flexible way to handle refining of cells in any direction a user wishes to.
REFINE IN ONE DIRECTION star Siemens 3 June 26, 2007 05:17
refine harry FLUENT 0 February 28, 2007 13:35
refine mesh harry FLUENT 0 February 23, 2007 11:00
REFINE Sunlight007 Siemens 2 December 6, 2003 15:40
Refine Stefano CFX 1 February 25, 2003 09:45
