creaction of a very small cylinder
Old   July 22, 2004, 05:11
Default creaction of a very small cylinder
toni
when creating a relatively big (r=1, L=20) in folder creating 3d grids with simple meshes (using cylindrical coordinates), there is a sort of plane between the 0 and 360 degreees, if i merge them the cylinder is perfect. However, I want to make a (r=0.00002 and L=0.0008) cylinder and when I merge the cylinder it collapses.
How can i make a small cylinder without any errors? Thanks
Old   July 22, 2004, 07:05
Default Re: creaction of a very small cylinder
Frederik
There is a value "tolerance", which must be set smaller than the grid spacing
Old   July 23, 2004, 12:04
Anton Lyaskin
...And the other way is to use different units when creating the model, not meters, and then speciying the geometry scale factor
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 08:59
small cylinder and big cylinder Eric CFX 1 January 26, 2007 05:38
Help meeee: Wave cylinder (sine cylinder) Ngoctq FLUENT 0 December 29, 2005 20:46
How Small is Zero ! Ajay Rao FLUENT 2 December 5, 2003 03:26
modeling of small size cylinder Tim Main CFD Forum 5 March 10, 2001 13:28
