common blocks
Old   November 9, 2004, 09:51
Default common blocks
CMB
Hi, this is a question that has more to do with fortran than star itself. Some times I use variables that I calculate in POSDAT.f and then use in other subroutines such as SOR*.f. My question is that, when looping the mesh with DO ic=1,nctmax and then reducing the loop for ictid(ic).eq.#. Then calculate a variable(ip) for this cell region. Why is it that if I define the variable I have to give it the size of variable(nctmax) rather than variable(# of cells in ictid(ic).eq.#)? Kind regards CM
Old   November 12, 2004, 09:41
Default Re: common blocks
4xF
Either you do not know which (STAR) cell numbers are belonging to the cell type # and in that case you have to dimension the array to have the size NCTMAX. All elements of the array (if initialised correctly) will be zero except for the cells with cell type #. If you need to have the array dimensioned to your needs (i.e. the same size as the number of cells with cell type #), you need to know the mapping between the cells with cell type #. Since all SOR* subroutines are called on a per cell basis, you will have to loop on the mapping to find out the desired cell to get the source term. Which is much slower than storing data and retrieving it from an array dimensioned to 1:NCTMAX.
Have fun...
COMMON blocks for passing arrays -- Please help marcus Siemens 6 May 6, 2006 09:46
sormom.f and common blocks Sheila Siemens 0 March 25, 2005 19:46
common blocks of STAR-CD Mari Siemens 2 January 26, 2005 03:21
how to define own COMMON blocks Mari Siemens 1 January 12, 2005 08:30
Common blocks in VISTUR Celia Siemens 6 December 26, 2004 02:25
