How to generate internal view?
Old   January 25, 2005, 07:44
Default How to generate internal view?
Harendra
Hello Experts,
How to generate an internal view of a trim/tetra hedral cell grid in Prostar/Proam?
Regards,
-Harendra
Old   January 25, 2005, 08:29
Default Re: How to generate internal view?
Stephane bone
A simple way to visualize your grid in prostar/proam is to click on "C->" Then Select New Zone. Define the Zone on your screen. Click on Cell Plot. Then, you have an internal view.
Old   January 25, 2005, 08:47
Harendra
Many thanks. It works. But forgive my one more question. How would I view through a slanted section of my geometry/mesh? That I want to view a sectional cut.
Regards
Old   January 25, 2005, 08:57
Stephane bone
To have a better view, you can use the command line :
cset newset xmin,xmax,ymin,ymax,zmin,zmax,1 (to select properly the zone you want to see.)
1 is for cartesian, 2 for cylindrical...
Click on Cell plot
Old   January 25, 2005, 09:40
steve
If you want a section slice:
1)click on the "Section slice button" - it will bring up a cursor that allows you to draw the slice through the current plot.
2)Click on "View->Snormal" to set the view normal to the section
3)Click on button underneath "Geometry Plot" and change it to either "Section (All)" or Section (Surface)" depending upon what you want to see.
You can also set everything individually by looking at the SPOINT, SNORM, VIEW, and PLTYPE commands
Old   January 26, 2005, 00:42
Default Many Thanks to both Stephane Bone and Steve
Harendra
I really appreciate your help. Thanks a lot.
-Harendra
[Commercial meshers] TGridFluent mesh with internal by prism layer and internal face for diagnostic sponiar OpenFOAM Meshing & Mesh Conversion 2 March 30, 2009 15:02
Generate 3D PDF/other 3D view from Gambit Skander FLUENT 1 March 27, 2008 06:03
how to get fluid internal internal energy vbk FLUENT 0 December 17, 2007 01:54
How to generate BFC grid? zczhang Phoenics 2 December 17, 2002 09:00
How to generate a curve leo Siemens 1 November 19, 2002 03:52
