negative values for diffusion scalar
Prev Previous Post   Next Post Next
Old   April 18, 2005, 06:21
Default negative values for diffusion scalar
cmv
Hi
The situation is very simple; I have defined a passive scalar and define it to be solved by diffusion. If you take a slab of cells and inject this passive scalar at one end and extract it at the opposite side, normally you would expect to have a zero value somewhere near the middle of the slab.
The problem is that I have not been able to get this 0 point at the middle of the slab but almost near the extraction region.
I have plot the value by monitoring the scalar at the injection & extraction regions but I get a correct value only on the injection region and I usually get a slightly negative value on the extraction region. I would expect these to be the same size but with opposite signs.
Do you know why it is not the same magnitude?
Preventing negative scalar (UDS) values?? Matthew Brannock FLUENT 5 September 1, 2020 12:32
diffusion coefficient in scalar equaton mike Siemens 0 August 30, 2006 11:42
zero flux boundary for diffusion scalar cmv Siemens 1 April 15, 2005 05:42
scalar advection-diffusion equation Darcy CFX 1 March 12, 2001 09:49
Diffusion Coef. of a Scalar C.H. Huang Main CFD Forum 2 August 18, 1999 03:48
