April 1, 2005, 12:20 |
Deferent Material
I am working with V3.22 on SuSe 9.1 linux. I do a mesh(Micro-channel sink) in Prostar but I want to define a deferent material (solid and fluid). I have problem between the fluid and solid mesh.What can I do to solve this problem? Could someone give me a hint? |
April 4, 2005, 03:40 |
Re: Deferent Material
Can you be a bit more specific?
April 6, 2005, 15:58 |
I do a mesh(Micro-channel sink) in Prostar but I want to define a deferent material (solid and fluid). I have problem between the fluid and solid mesh. What kind of Boundary I have to use? What can I do to solve this problem? Could someone give me a hint? |
April 7, 2005, 11:02 |
You have to use a conducting wall boundary between the solid and the fluid. don't forget to switch on the conjugate heat transfer.
April 18, 2005, 11:12 |
if you use conjugate heat transfer technique, you do't need to define any internal boundary condition between solid and fluid. The program will caulculate the heat tranfer between solid and fluid automatically.
New Material | M.E. | FLUENT | 6 | June 11, 2007 10:06 |
mixture type material as a phase material | Pablo | FLUENT | 1 | January 25, 2007 10:54 |
Material in DPM | yooceframandi | FLUENT | 8 | March 10, 2006 08:19 |
a new material | Neser | CFX | 0 | February 17, 2005 11:47 |
Add New Material | davis | FLUENT | 1 | September 4, 2003 06:51 |
