Asking for help! Thanks a lot!
Old   May 14, 2005, 02:02
Default Asking for help! Thanks a lot!
Yang Bin
Dear all:
This problem is focused on heat exchanger in typical air-conditioning system. I want to know whether the latent heat transfer caused by condensating of moist air can be coupled with sensible heat transfer in simulation successfully? I want to simulate the whole process when moist air come through the cooling coil in both air side and water side.
I have asked this question for several times. Please help me if you have some experiences in this filed. Thank you very much!
Yang Bin From Singapore
Old   May 16, 2005, 01:02
Default Re: Asking for help! Thanks a lot!
sankar
I am also trying for the same. i feel that this is not possible in starcd.
sankar
Old   May 16, 2005, 06:24
Yang Bin
Do you consult with some experts?
