setting variable boundary
Old   January 24, 2006, 11:52
Default setting variable boundary
Mehdi
Please help me in this problem: I want to use outlet massflow and temperature of one face as inlet for another face of course at the same model. any body knows what I should do for it? I'm thankful in advance.
Mehdi
Old   January 25, 2006, 01:14
Default Re: setting variable boundary
TomK
I guess the only way is to use user-subroutines: posdat.f for integrating massflow and temperature at the outlet and transfer these data (e.g. common block) to bcdfi.f
this should work. maybe you'll need some kind of relaxation due to stability problems
Old   January 25, 2006, 01:19
novice
try negative inlet.
Old   January 31, 2006, 04:33
Yacine
did you try partial periodic boundary conditions? then you can impose the massflow and the temperature.
Setting working environment variable Arthur FLUENT 0 December 10, 2008 04:33
how to setting this boundary tipakorn Siemens 4 January 16, 2008 08:19
Setting rootcase variable carlo_fabrizi OpenFOAM Pre-Processing 0 May 8, 2006 14:22
Setting a boundary conditions mer OpenFOAM Running, Solving & CFD 1 November 24, 2005 13:53
variable time step:setting global courant number Cedric FLUENT 0 July 28, 2005 09:14
