calculation of heat release rate
Old   February 8, 2006, 06:01
Default calculation of heat release rate
paul
Pls. anybody tell how to calculate heat release rate from the post pstt files.
Old   February 11, 2006, 18:06
Default Re: calculation of heat release rate
DB
I have to write a small code in postdat.f file to get the heat release rate for my case maybe you should also consider the same thing
Old   February 15, 2006, 11:21
paul
Can you please let me know how to use postdat.f. I Guess it is a user subroutine. So far I have not used any user files (ufile) for calculating the post quantities. Please give the sample code to calculate heat release rate so that I could develop on that
Thanks in advance
Old   February 16, 2006, 03:40
Ben
contact your support guys, this is covered in one of the training courses I think, they should be able to give you the routine you need.
heat release rate simulation chiang Siemens 10 April 29, 2021 06:10
heat release rate calculation Karthick .K FLUENT 2 April 28, 2021 22:15
heat release rate in output file Caty CFX 6 June 16, 2014 11:06
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 18:49
heat release calculation caty Main CFD Forum 1 February 4, 2005 09:28
