posdat.f Problems
Old   February 16, 2006, 00:54
Default posdat.f Problems
kris
I uses STAR-CD v3.26
When OPEN function is included, this kind of problem is occuring.
If posdat.f is excluded, it is working very well without any problems
******************* posdat.f *************************
~~~~~~~ abbrev.~~~~~~
IF(LEVEL.EQ.2) THEN
IF(INTFLG(1).EQ.0) THEN
OPEN (84,FILE='MonP.dat',FORM='FORMATTED',STATUS='UNKNO WN') ==> Error position!!!
DO I=1,INUMBER
DO J=1,NCTMXU
IF(IPROSTAR(I) .EQ. ICLMAP(J)) THEN
******************* Running ********************************
1 5.40E-01 3.13E-01 1.33E+00-1.01E-04 1.40E-05 1.27E-02 1.47E+08 -1.06E-03-1.51E-03 6.03E+00 2.02E+00 6.84E-01 1.92E+01 1.94E+03
-1.97E-07-5.33E-06-3.42E-06 3.58E-07-8.40E-06-7.34E-05 0.00E+00 4.19E-03 6.44E-02 6.35E-05 2.06E-03 9.86E-02 7.18E-01 0.00E+00
-1.60E-05 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 1.78E-01 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00 0.00E+00
[ 1 ] ***Received signal sigsegv - exiting
PNP: Shutdown [2006-02-16-04:13:15] Execution aborted by request (SIGABRT) after 9 seconds (TOTAL ELAPSED TIME).
1060% [kris@node01 transient]#
Old   February 16, 2006, 11:05
Default Re: posdat.f Problems
John Luo
It's not easy to see the problem because you only put part of your code, try this IF(LEVEL.EQ.2) THEN
IF(INTFLG(1).EQ.0) THEN OPEN(84,FILE='MonP.dat',FORM='FORMATTED',STATUS='U NKNOWN') INTFLG(1)=1 ENDIF .....
Old   February 20, 2006, 01:42
kris
in this code
If OPEN command is NOT included, No Error occures.
If OPEN command is included, Error occures and the result is as follow
POSDAT.F Test Source file
SUBROUTINE POSDAT(KEY,VOL,U,TE,ED,T,P,VIST,DEN,CP,VISM,CON,
* F,ICLMAP,ICTID,RESOR,VF,FORCB,IRN,PREFM,LEVEL) !C Post-process data !C************************************************ ************************* !C--------------------------------------------------------------------------* !C STAR VERSION 3.20.000 * !C--------------------------------------------------------------------------*
INCLUDE 'comdb.inc'
COMMON/USR001/INTFLG(100)
DIMENSION KEY(-NBMAXU:NCTMXU),VOL(NCTMXU),U(3,-NBMAXU:NCMAXU),
* TE(-NBMAXU:NCMAXU),ED(-NBMAXU:NCMAXU),T(-NBMAXU:NCTMXU,1+NSCU),
* P(-NBMAXU:NCMAXU),VIST(-NBMAXU:NCMAXU),DEN(-NBMAXU:NCTMXU),
* CP(-NBMAXU:NCTMXU),VISM(-NBMXVU:NCMXVU),CON(-NBMXCU:NCMXCU),
* F(3,-NBMAXU:NCMAXU),ICLMAP(NCTMXU),ICTID(NCTMXU),
* RESOR(89,-100:100),VF(NCDMXU),FORCB(3,NWLMX),IRN(NWLMX)
DOUBLE PRECISION P
DOUBLE PRECISION T
DOUBLE PRECISION TE
DOUBLE PRECISION ED
DOUBLE PRECISION U
DIMENSION PREFM(4)
INCLUDE 'usrdat.inc'
DIMENSION IPROSTAR(100),ISTAR(100),IBOOL(100)
DATA IPROSTAR/100*1/
DATA IBOOL/100*0/
DATA ISTAR/100*1/
IF(LEVEL.EQ.2) THEN
OPEN(84,FILE='MonP.dat',FORM='FORMATTED', STATUS='UNKNOWN')
CLOSE(84)
700 FORMAT(A8,1P,I20,I20,I20,I20,I20,I20,I20,I20,I20,I 20,I20
* ,I20,I20,I20,I20,I20,I20,I20,I20,I20,I20,I20) 800 FORMAT(F10.8,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20. 13,
* 1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13, 1X,E20.13,
* 1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13,1X,E20.13, 1X,E20.13)
ENDIF
ENDIF
RETURN
end
CFL in posdat hamodi Siemens 2 August 6, 2007 02:27
posdat.f - other problems kris Siemens 0 February 24, 2006 01:05
POSDAT Sheila Siemens 2 February 8, 2006 11:08
posdat in HPC Won-Geun Lee Siemens 0 May 23, 2001 20:03
Posdat Maria Carlsson Siemens 1 April 30, 2001 10:29
