February 21, 2006, 13:02 |
How to run cases automatically?
Hi. I have different cases and want to run them one after one (night time) automatically. Your help will be very much appreciated. Wael
February 21, 2006, 23:17 |
Re: How to run cases automatically?
Hi
Use the following step to do that: 1.Create a folder say "batchRun". 2.Pre process all the model which has to be run in batch mode. 3.Save the first model in batchRun folder, and for other models creat separate folders for each run, save the models in these folders (one model in each folder). Say folder names are "case2", "case3", etc. 4.Save the *.mdl, *.geom., *.prob, and, parm.inc, in respective folders. 5.Now create a text file in batchRun folder with following text: star â€"dp hostname, 2 (help: star is for star solver, -dp is double persion, hostname is computer host name, e.g. localhost etc., 2 is for number of processors, this will run the first case, which is there in batchRun folder) cd ./case2 (help: to change the directory to case2 directory) star â€"dp hostname, 2 (help: to run the case in case2 directory) cd ../case3 (help: to change the directory to case3) star â€"dp hostname, 2 (help: to run the case in case3 directory) 6.Save the text file as "batch.sh". 7.In terminal go to batchRun directory and issue the command "source /opt/star/v332/etc/setstar" 8.To give permission to the batch.sh file, give the command chmod 777 batch.sh 9.Now to run the analysis issue the command "./batch.sh" this will run the cases one after the other. Results will be saved in the respective folders |
February 22, 2006, 01:59 |
Hi. Thank you very much Mr. Manish for your detailed reply. I will try the steps. However, I am working on WinXP computer. Are the steps the same?. My best wishes and regards. Wael
February 22, 2006, 04:46 |
Hi I use Linux RH Ent V4. So, commands are for Linux. You can change according to windowsXP. Like for "batch.sh" (shell script in Linux), you may have to use similar version of file in Windows (may be *.dll or *.inf).
February 22, 2006, 07:23 |
for windows *.bat
February 22, 2006, 08:27 |
Thanks alot Mr Manish and Mr Carno. I tried the *.bat ( star -dp then cd.. then cd case2). It is working for the 1st case only and stop. Many trials but faild. Please give more a hand and my best regards to all of you. Wael
February 23, 2006, 06:09 |
Use call:
call star -dp hostname,2 then cd.. then cd case2 call star -dp hostname,2 |
February 24, 2006, 09:01 |
It is working well, Thanks a lot
Thank you very much Mr. Rostislav, The batch file is working after your modifications. Also thanks to all whom gave help. My best regards. Wael
How to perform TIME_AVERAGE automatically | Saim | FLUENT | 0 | January 22, 2007 09:43 |
Merge Nodes automatically | Timmy | CFX | 1 | December 6, 2006 08:51 |
Can CFX Automatically generate hybrid meshes? | JJ | CFX | 0 | August 28, 2003 21:18 |
Automatically saving a line graph | Astrid | CFX | 1 | April 28, 2003 06:48 |
