March 8, 2006, 05:45 |
error 84 couple error
How to correct error 84, master cell face in one couple is defined as a slave cell face in another couple. Thank you
March 8, 2006, 05:47 |
Re: error 84 couple error
Delete the couple and redo the coupling with proper master and slave cells defined.
March 9, 2006, 02:44 |
Thank you, But I can't do it. Please tell me more detail.
March 9, 2006, 04:53 |
You can control which cell is used as a master and which one as a slave by assigning different cell types. Use the couple tool for creating, checking, deleting couples.
March 9, 2006, 05:52 |
hi tipakorn
try with this option in prostar - tools - couple tools go for couple check - use YES option at remove non overlapping slaves this may help you ..all the best anand |
March 10, 2006, 01:47 |
Thank you I used to do this but there are errors.
March 10, 2006, 17:35 |
It may be that the chunck of cells in question are just badly formed. Cut out the cancer and put something better in - make new cells and cpmatches.
strange fluent error: Primitive Error at Node 0 | Jean-Baptiste | FLUENT | 8 | June 14, 2022 11:11 |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 00:23 |
COUPLE ERROR | star | Siemens | 3 | May 17, 2007 05:19 |
Couple error | Yehia | Siemens | 3 | January 25, 2007 03:58 |
Fatal error error writing to tmp No space left on device | maka | OpenFOAM Installation | 2 | April 3, 2006 08:48 |
