March 16, 2006, 11:45 |
Ignition and combustion
I have to model the propagation of a flame in a tube with StarCD. However I don't know how to create an ignition and the reaction of combustion between the air and Butane (Calor gas) with StarCD. Could you help me, please ? |
March 21, 2006, 04:02 |
Re: Ignition and combustion
For modelling the ignition mechanism inside STAR-CD, you have to select some ignition cells to be defined as spark plug. The, you have to apply it as different cell table & colour (if possible). Then key-in the starting of ignition process to the end of ignition in the forms of time steps or crank angles. The the combustion will occured automatically once you have set-up your chemical reaction properly. Actually, you can refer to STAR-CD User Guide and Tutorial to do that. This is from me at this time. Thank you. Regards, wendy |
April 5, 2006, 09:31 |
Hello!
Thank you a lot for your response. I have made what you told me in StarCD but I can't find where the option spark plug is and I don't understand why there isn't any Air in my tube whereas I have set up my chemical rection properly. I can't see a varition of temperature since the combustion doesn't occur. Could you help me once again, please? Best regards, Mai |
April 5, 2006, 09:38 |
Which combustion model do you use?
April 5, 2006, 10:04 |
I use a model of combustion with premixed gaz ( In fact, I'd like to make butane C4H10 and O2 react with StarCD)
April 5, 2006, 10:23 |
There are a few options for premixed combustion. which one do you use?
April 12, 2006, 08:31 |
I have chosen a CHKI rate model of combustion, with the option Standard and a local source but I can't enter Ignition parameters, do you know why, please ?
May 10, 2006, 09:59 |
Combustion
I would like to model the propagation of a flame in a tube with Star CD. I have enter the reaction of combustion of C4H10 properly but I can't have a result. In fact, there isn't any variation of parameters concerning O2 and the other elements. Could you help me please ? |
Qs on combustion/ignition in CFX 5.5.1 | beginner1 | CFX | 6 | August 6, 2010 11:16 |
Ignition timing for diesel combustion | Ankur | Siemens | 5 | March 15, 2008 20:18 |
Review ignition models for ICE combustion | Berny | Main CFD Forum | 0 | June 3, 2005 04:34 |
Constant Volume Chamber - Combustion and Ignition | KOchzg | FLUENT | 0 | March 30, 2005 10:19 |
Combustion, ignition limits and dealy | Nebojsa Milovanovic | Main CFD Forum | 2 | April 18, 2000 03:58 |
