How to make movies in star-cd....
Old   August 16, 2006, 09:42
Default How to make movies in star-cd....
Albessu
I'd like to know if there's a free software to compile the pictures made inside proam, because as I know we don't have the possibility to create movies inside proam, is that right?
Old   August 16, 2006, 17:59
Default Re: How to make movies in star-cd....
Pauli
It will depend upon your OS. I'm on Redhat Linux & use the convert command.
My process is to create a Prostar neutral plot file. Then use the plot utility to create a series of gif files named X00???.gif. Then I issue the convert command as follows: convert -X00???.gif Movie.gif
This creates a multi-image gif file. Convert supports a range of file formats. Try doing a man on convert and a man on ImageMagick & you can see the details.
Old   August 17, 2006, 02:32
pp
ImageMagick is available for Unix/Linux as well as for Windows OS-s.
Regards, pp
Old   August 17, 2006, 06:00
Albessu
Thanks Pauli & pp for your attention...
Old   August 17, 2006, 12:55
paulh
gifmerge is also a good utility although perhaps a little old now
Old   August 17, 2006, 16:40
Ben
try whirlgif, although I am not sure if it is available for windows but then again if you use windows you deserve all you get!
how to make animation in star ccm *NM* raziftech Siemens 3 October 17, 2007 02:35
how to make movies by FIELDVIEW? hui FieldView 1 September 28, 2006 16:42
[OpenFOAM] Saving images and movies shuo ParaView 0 September 24, 2006 20:23
movies with PHOTON Kostas Pikos Phoenics 12 October 1, 2001 10:59
CD with fluid dynamics movies? George Bergantz Main CFD Forum 1 August 2, 2001 23:42
