Warning query
Old   January 19, 2007, 06:02
Default Warning query
Salman
Hi All I am continuously receiving the following warning, ispite of the fact that the convergence criteria is always achieved. So please tell me about this warning and how to overcome it. Thanx Salman
"*** WARNING #090 *** VALUE ELOG*YPLUS OR ELOG*EFFVIS/(CAPPA*VISCOS) IS LESS THAN 1.1 AT 832 CELLS. UPLUS=YPLUS LAW IS USED. IF THIS SITUATION PERSISTS, INCORRECT RESULTS MAY BE OBTAINED."
Old   January 19, 2007, 10:10
Default Re: Warning query
george
Dear Salman,
I have also the same warning message in every run I do. I think that it has to do with the wall boundaries. Do you use standard wall boundaries for the standard k-e turbulence model? I think it has to do with the parameter y+ and u+ and the number of the cells we use to describe near wall treatment. I try to find out what maybe the problem is.
George.
Old   January 22, 2007, 07:17
pathak
You try to change the turbulence model. I had experienced the sanme .it works. good luck
Query Rishikesh FLUENT 16 September 18, 2008 04:40
Query Rishikesh Main CFD Forum 0 September 15, 2008 02:49
MRF query sandip Siemens 1 July 4, 2008 05:24
query sihat FLUENT 0 June 18, 2006 21:00
Query RAJURAMAIAH CFX 0 December 5, 2004 23:13
