Is the Residual acceptable?
Old   February 2, 2007, 09:02
Default Is the Residual acceptable?
Boon Ping , Oh
I'm currently doing two simulations. One of the Residual diverges in the beginning for around 100 iterations. Though it converges eventually till 0.001. Is it fine and acceptable? Another one diverges abit in the beginning and have zick zacks when the residual stays 0.001. I've checked the Cell Quality, whether I#m using the right Condition, checked the Wall Y+ and it's all fine. Are both the Simulations not acceptable? Are those Simulations, which Residuals have zick zacks of diverge few times but eventually converge acceptable?
Old   February 2, 2007, 09:48
Default additional question: Is the Residual acceptable?
Boon Ping , Oh
Is it alright for the residual diverges few times before it converges to 0.01?
Old   February 2, 2007, 10:17
Default Re: additional question: Is the Residual acceptabl
sidd
Ping,
For the fluctuation part, you should notice the level of deviation of you residual. There may be local fluctuations, but if the overall trend is decreasing then you can rely on it. These fluctuations give an indication of how stable your simulation has become. And these fluctuations come mostly due to some local-domain parameters' imbalancing. If your area of intereset is to focus on global values, then its better that you rely on these values.
Most practical method is to look into your result and check for unrealistic values of solving parameters in your calculation domain, if it is there.
Regards,
Is such Residual acceptable? Boon Ping , Oh Main CFD Forum 8 February 5, 2007 03:54
Convergence on Local Time Scale Acceptable Turbine CFX 7 August 14, 2006 08:13
Acceptable Pressure Gradients Jason FLUENT 0 February 18, 2005 09:09
Acceptable Gradient Values Raman Chadha FLUENT 0 January 12, 2005 18:00
Acceptable Accuracy or Error? Erich Main CFD Forum 6 July 2, 2001 13:30
