problem Hcoeff display
Old   February 1, 2007, 07:54
Default problem Hcoeff display
raffap
I have perfored an aanlysis and I'm trying to disply the hcoeff, but I can't the following message appear: wall variable hflu is not on the data file...what that means???
Old   February 1, 2007, 09:23
Default Re: problem Hcoeff display
george
Hello raffap,
What is hcoeff? A coefficient which concerns a wall parameter?
George
Old   February 1, 2007, 09:26
raffap
hcoeff is the heat transfer coefficent, I have to display this coefficent on a wall boundary. the command is getw-->hcoeff,tbulk
Old   February 1, 2007, 11:04
PETE
did you post it in .pst? You have to choose post in the output tab
Old   February 1, 2007, 16:36
Balduin Bankerotti
Select it at the output tab and do a restart run with zero iterations and hcoe should be in the *.pst file.
If you are using version 4 without solving the temperature equation you mith have to cheat a bit and tweak the *.prob file using the following script:
#!/usr/bin/perl
print "modifying *.prob-File for writing htran\n";
if (!defined $ARGV[0]) {
print "USAGE : htran.pl casename\n";
exit;
$case = $ARGV[0];
$file = "${case}.prob";
$line = "POSTWL SHEA YPLU DIST HTRA";
open(IFILE , "<$file") || die "Datei $file ist nicht vorhanden";
@alles = <IFILE>;
$text = join("",@alles);
close(INFILE);
$text =~ s/POSTWL.*/$line/;
open(OUTFILE , ">$file") || die "Datei ... ist nicht vorhanden";
print OUTFILE "$text";
close(OUTFILE);
Old   February 1, 2007, 16:39
Balduin Bankerotti
The forum software has some problems with perl code.
the line with @alles should be
@alles = <_IFILE_> ;
without the "_" characters
Old   February 2, 2007, 03:09
Default yplus value in heat transfer
kathir
hi expert my problem is finding the heat transfer coefficient around the cylinder in a uniform flow. but i got the ypus value nearly .5 to 3. according to my theoretical knowledge for this yplus value k-e model overpredict the heat transfer. how to get the accurate heat transfer coefficient. but i cant provide the fine mesh in near walls because i want to find the boundary layer effects how to use wall functions for this kind of problem
by kathir
Old   February 4, 2007, 13:57
Default Re: yplus value in heat transfer
analyse In India
Hi raffap, Check whether your postprocessing Result file or restart file. I have this problem some time before, I had spent nearly a day to plot HTC from, without noticing that I am loading restart file.
problem with display john FLUENT 8 March 14, 2009 11:40
3D display problem Victor Cano FLUENT 1 December 18, 2008 19:35
StarCD display problem cfddummy Siemens 3 April 9, 2007 16:59
star-CD V 3.26 - GUI display problem. Dr C.Bhasker Siemens 9 July 17, 2006 07:27
Tbulk for Two Layer hcoeff Peter Siemens 0 June 2, 2004 02:42
