June 20, 2007, 06:05 |
Negative Densities
Hello I am simulating a pulsating(piston) pressure inducer in a closed(no outlet or inlet) system. The pressure should rise from 30 bar to 4000 bar. But after a few time steps the solution stops and gives out the error "negative densities found in more than 100 cells". When I increase the volume of the system more time steps have been carried out, but still the process was aborted! I also recognized that the velocities are negative in some time steps during the compression stroke, which shouldnt be possible!?! Anybody has any advice for me? Would be really grateful for any help!
Greets Chris |
June 22, 2007, 04:36 |
Re: Negative Densities *NM*
June 22, 2007, 04:39 |
Hi, you are bound to get negative densities with these kinds of simulations. Try using user coded density, since the pressure greatly rises and there may be compressibility issues (for a high viscous liquid).
June 22, 2007, 06:17 |
Thx, worked out with high viscosities!
June 25, 2007, 08:39 |
Still, does anybody have an advice for the negative Velocities in the compression stroke?????
negative densities | john | Siemens | 0 | March 19, 2008 06:32 |
negative densities | Riyaz Ahamed | Siemens | 2 | August 14, 2007 01:47 |
Negative Densities | shyam | Siemens | 2 | May 8, 2005 06:17 |
negative densities | CMB | Siemens | 4 | January 4, 2004 02:41 |
negative densities. | Mihir | Siemens | 4 | December 9, 2002 21:04 |
