time step in free surface problems
Old   June 21, 2007, 09:18
Default time step in free surface problems
KtoTo
Hi! My question is: I try to solve free surface problem in transient mode and set Time Step in Advanced Transients panel. But when solving STAR-CD decreases this value to obtain correct free surface probably. How can I use greater Time Step? (by changing Courant number, numrer of Cycles?) Thanks
Old   June 25, 2007, 05:50
Default Re: time step in free surface problems
rui
you'd better not do that. Or you cannot get reasonable free surface results
Old   June 25, 2007, 08:19
KtoTo
Why do you think so?
Old   June 26, 2007, 03:27
murash-v
hi. From what data you done this conclusion? I had often work with free surface and never saw like this. Try to use double precision - it is advice of cd-adapco. Can you answer for me: "From what data you done this conclusion?". You may do it in koi8-r or cp-1251
Old   June 26, 2007, 07:03
KtoTo
Hi, murash-v, if you asked me , after .pstt file has been loaded, I saw that time of time steps is not equal TimeStep multiplied by time step number but varies at PC will. I try to simulate vibration of cistern with water. I should be able to answer in koi8-r or cp-1251 , but anybody can take an interest in this problem.
Thanks for answer.
Time to converge with free surface (PICTURE) Mark CFX 7 October 30, 2006 20:46
Free surface height v/s time ashish CFX 2 October 4, 2005 14:13
Free surface of Step with VOF Azin Sharafeddin FLUENT 1 May 26, 2004 05:24
Surface monitor at every n:th time step Victor FLUENT 3 March 4, 2004 23:46
problems with free surface seba FLUENT 1 October 11, 2001 18:32
