Sensorpoints for interpolation
Old   August 2, 2007, 08:44
Default Sensorpoints for interpolation
Gabriel
Hi there, my problem is, that I need some solution-data on user-specified points, which I have given as a result of experiments. I have to valid my CFD calculations with the experiments. Do you know how I can get these values of for example velocity on this special points? Is it possible to interpolate the data from cells nearby.
Old   August 3, 2007, 08:37
Default Re: Sensorpoints for interpolation
James
I believe you are looking for the command SENSOR.
You create vertices at the required points, add them using the sensor command, load in either cell or vertex data and finally scan and print the data once again using the sensor command.
If you use vertex data it will then interpolate to the point in space, cell just uses the value it is in. Which is more accurate is difficult to say as vertex data has already been averaged.If it makes a big difference your mesh was probably too coarse in theis area to begin with.
The number of sensors allowed is set by the MAXPRB variable which I think is set to 200 by default.
3D interpolation Nena CFX 0 October 31, 2007 04:12
INTERPOLATION ED FLUENT 0 March 8, 2007 15:58
3D interpolation Lipo Wang Main CFD Forum 4 August 20, 2004 01:12
3D Interpolation Kyung-Seok, Kim Main CFD Forum 2 August 17, 2004 09:03
2D-Interpolation Don Tron Main CFD Forum 3 October 30, 2003 03:40
