Memory Allocation in STAR-CCM+
Old   November 20, 2007, 10:10
Default Memory Allocation in STAR-CCM+
Forrest Carpenter
I am new to STAR-CCM+, and I am wondering how to allocate memory to a job that I am running locally on my desktop. I wonder because my simulation fails the memory check at the very beginning. I have 2GBs of memory available, and the simulation that I am running has 1.2 million polyhedral cells. I am running version 2.10.013
Old   November 20, 2007, 12:29
Default Re: Memory Allocation in STAR-CCM+
Harry
You don't allocate memory with STAR-CCM+ it does it for you, 1.2 million polys is probably pushing it on that machine, remember it is a faced based solver and polys have more faces than tets or hexas. If you have anything other than base physics this will also use up more memory. Finally if you are using windows, give up now, the OS eats so much memory running junk apps in the background you actual physical memory available is probably under 1.5gigs
FloWORKS memory allocation? Casey FloEFD, FloWorks & FloTHERM 14 October 21, 2012 13:11
memory allocation failed Li Yijin Fidelity CFD 3 January 29, 2008 21:42
Memory Allocation Harish Main CFD Forum 0 July 26, 2005 15:29
memory allocation strudl CFX 1 October 5, 2003 10:26
dynamic memory allocation in C++ m. malik Main CFD Forum 13 September 12, 2002 06:52
