units problem
Old   October 30, 2007, 08:39
Default units problem
hass
hello i am doing diesel combustion problem. i want to know when i use thermal Nox and Mauss soot model in which units i geet my results i.e NOx and SOot values
Old   October 30, 2007, 10:28
Default Re: units problem
usker
mass fraction
Old   October 30, 2007, 12:31
hass
thanks but can you tell me how to change units in to g/kWh
Old   October 31, 2007, 08:12
dong
Get the mass flow of your emissions at the outlet. This should be in your info file. If not use the 'operate' commands to get a value. Divide by the heat input into your system.
Old   November 1, 2007, 08:58
Andrea
q_SOOT (or q_NOx) in [g/(kWh)] if I'm right it's:
SOOT_conc*cyl_mass*60^2*10^6*number_of_cyl/(pme*cyl_max_volume)
where pme is in Pa (Star writes in Pa) and cyl_max_vol is in m^3
Old   November 5, 2007, 09:38
hass
Hi Andrea Can u tell me whats pme in equatoin you gave
Old   November 5, 2007, 19:59
usker
mean effective pressure
Old   November 6, 2007, 03:19
hass
Thanks
Old   November 8, 2007, 11:40
Andrea
yes, and note that cylinder mass in that formula it's in kg as written out by Star
Units? Skander FLUENT 1 February 5, 2007 09:10
Problem With Scalar Units Carlos V. FLUENT 0 May 2, 2006 10:59
What's the units in UDF? Erica FLUENT 3 March 3, 2005 18:40
What's the units? ocy FLUENT 3 February 23, 2005 21:40
Units of P CFD guy Phoenics 1 December 29, 2004 05:35
