Initialisation in transient simulation with ASIs
Old   January 29, 2008, 12:12
Default Initialisation in transient simulation with ASIs
Phil D
I have a serious problem in setting up a transient simulation including ASIs with my state-state solution as the restart pst-file. For my steady-state calculation I had to connect (couple) the cell faces at the sliding interface (and delete the ASIs). The result is fine but it does not work as initialisation of my transient simulation.
Does anyone know why? Is there anything else I have to consider?
Thanks in advance,
Phil D
Old   January 29, 2008, 14:26
Default Re: Initialisation in transient simulation with AS
Balduin Bankerotti
Just do an smap.
Old   January 29, 2008, 16:25
James
The flow is held in the reference frame of the fluid, not the absolute reference frame. The pressure and all scalar fields should be fine.
You therefore need to get the velocities in the global reference frame and then push them back onto the post file before SMAPping. UPDATE or operate putc should probably work.
I would advise taking a copy of the post file first as this may take a couple of tries! Once you have figured out the commands it is pretty easy.
Old   January 29, 2008, 18:14
Philipp Daus
Ok thanks, this sounds like an useful approach.
Starting my transient simulation I got this error message: __________________________________________________ ___________ *** READ RESTART FIELD FROM FILE turbine_neu.pst **ERROR - READING POST FILE:
ND1 / ND2 Error FB IN R9SF1 : DIMENSION ERROR __________________________________________________ ___________ Any idea? Does this match your approach?
Thanks again!
Old   January 29, 2008, 18:32
Balduin Bankerotti
This was the case in version 2.1 of starcd
Now it is possible to do the smap without dealing with absolute or relative velocities.
Old   January 29, 2008, 18:35
Balduin Bankerotti
You try an restart run, which will not work.
You have to do a "rdat init c" to read the smap file.
Old   January 30, 2008, 03:11
Philipp Daus
I am working with version 3.26
Old   January 30, 2008, 07:44
James
That was probably about the time I last tried it ! Isn't progress great.
Transient simulation Pramila Main CFD Forum 2 October 1, 2010 04:01
Transient simulation astro1 FLUENT 0 October 22, 2006 10:28
Transient simulation Cathy Lee FLUENT 0 August 30, 2005 14:40
Anyone use RSM in transient simulation? Pete Main CFD Forum 0 March 13, 2005 03:29
is this a transient simulation? Joana Main CFD Forum 7 March 11, 2005 14:41
