plotting force magnitude
Old   June 3, 2008, 04:00
Default plotting force magnitude
force
When i plot force magnitude on a wall surface, i get a range of force value from 0 to some positive number and there is no negative number plotted. Is it not possible to plot negative value of forces or is it because Star-cd can't extract negative value of aerodynamic force? I think a force pushing on the surface should be positive value and a force lifting the surface should be negative value and negative value of force should exist to represent effect of suction due to low pressure in high velocity regions.
Old   June 3, 2008, 07:28
Default Re: plotting force magnitude
James
Negative values of force are possible. You may have extracted the wrong forces, there are quite a number of options and it can be confusing.
Old   June 3, 2008, 11:56
Pauli
Isn't force MAGNITUDE = sqrt(Fx^2+Fy^2+Fz^2). If so, then you should look at the individual components.
Old   June 4, 2008, 05:56
force
yes, magnitude should be that (all positive) but i need to plot force magnitude in normal direction of the surface, not simply Fx or Fz or Fz but a combination of all .. somehow, a force component in the normal direction of surface? Is it possible?
Old   June 7, 2008, 07:20
reza
The force normal to the surface is caused by the pressure. If you want to have a negative value, you should plot the total pressure.
Force = pressure * area
the area is the cell area on which the pressure is being ploted. you should be able to load this value manually in the post register in addition to the pressure value.
eg. pressure in register 4 and area in register 5. put the new value in register 6 then plot it.
you should get a negative value.
cheers
Old   July 11, 2008, 00:37
force
should the area typed in be the area for each range of pressure in the legend or the area of the entire surface?
Old   July 11, 2008, 04:19
Reza
The area should be the surface on which the pressure is being plotted. You can maipulate this with in the post register.
Klick on OPERATE then....FUNCTION
Choose LOAD CELL DATA...then AREA...then choose the register you want to put the data into.
Cheers!
Vorticity magnitude CFD-junior Main CFD Forum 10 October 8, 2021 03:42
y+ and velocity magnitude Simone Main CFD Forum 3 December 12, 2008 06:44
MRFZonesC questions what is the mesh_V and why only Coriolis force no centrifugal force waynezw0618 OpenFOAM Running, Solving & CFD 49 April 8, 2008 04:23
Plotting ribbons with mapped velocity magnitude Ulf Siemens 1 July 30, 2004 08:00
Vorticity magnitude Hernani Siemens 2 August 20, 2001 09:48
