Negative densities at more than 100 cells
Old   October 11, 2008, 03:59
Default Negative densities at more than 100 cells
Luke
Hey everyone, I'm pretty new to Star-CD and am having some problems with a model that I have been trying to get running for quite a while now.
Basically what I am trying to do it to inject some fuel into a constant volume chamber. This is the starting point and then I will introduce a porous medium but this basic setup isn't working. I have run some models using es-ice in which I have sprayed fuel into the moving cylinder and they worked fine but now I am just trying to simulate fuel spray at one set crank angle (i.e. just a fixed volume) but I get an error that says: "Error 076: Negative densities at more than 100 cells" after only a few iterations. The fuels starts injecting before the error and everything seems to be as expected at these iterations.
If anyone know what the problem might be, I would really appreciate it.
Thanks
Old   October 14, 2008, 21:12
Default Re: Negative densities at more than 100 cells
cachinarcrc
I have got the same error"Error 076: Negative densities at more than 100 cells" when I simulate the diesel engine,and the soft Engineers sometimes have not idea to deal with it except for asking for "reduce the time step,or uder-relaxation factor,etc".But this is no useful.
Old   October 15, 2008, 10:14
usker
try to locate your injector a little deeper into the domain (not on the surface of the domain)
Old   October 15, 2008, 18:00
Luke
Thanks for the tip. I have located the injector 1.5mm radially the edge and 1.3mm in the z-direction. The other thing is that it gets the negative densities much before the fuel injection starts. Any other ideas?
Old   October 27, 2008, 15:52
allan
You can try checking your reference pressure or relax very heavily on temperature and density or if you have a pressure outlet make sure that the pressure on it is realistic.
allam
Old   December 2, 2008, 04:14
Emir
you should change your time step and then your problem will be solved
negative densities Riyaz Ahamed Siemens 2 August 14, 2007 01:47
Negative Densities Chris Siemens 4 June 25, 2007 08:39
Negative Densities shyam Siemens 2 May 8, 2005 06:17
negative densities Sabatini Siemens 4 January 31, 2002 08:06
negative densities Fabrizio Grieco Siemens 4 October 30, 2000 01:47
