modify ccmp for initialisation
Old   August 12, 2009, 11:06
Default modify ccmp for initialisation
Thomas Baumann is on a distinguished road
Hello all,
I'd like to modify my postprocessing results from a ccmp file.
I simulate a large eddy simulation of a channel flow with cyclic boundary conditions.
I begin with simulating the channel with RANS-Modells to get initialisation values for my LES. That works without any problems.
But I get a laminar profil in the LES. It is a channel flow with a Reynolds number about 50000. So it should be turbulent.
I think the problem is the initialisation profil, because there are no fluctuations of the velocity and pressure because of turbulence. Is there a possibility to change the values in the *.ccmp data I use for initialisation of the LES?
Thanks, Thomas
Thomas Baumann is offline   Reply With Quote
Old   August 12, 2009, 11:33
Aroon
vishyaroon is on a distinguished road
Are you sure it is a problem with the restart?
Are you running LES on a smooth channel? In case of unsteady RANS models you still might develop into a turbulent flow in a plane channel, but with LES if you do not have some kind of a turbulence generator, then your flow is bound to relaminarize. Can you check if this is what is happening. This should not be a problem in RANS as the turbulence equations take care of it, but the LES turbulence has to be artifically generated.
vishyaroon is offline   Reply With Quote
Old   August 13, 2009, 02:39
It's a channel with walls on top, bottom, left and right.
Solving with normal RANS the velocity-profils are turbulent. Using these results for initialisation it relaminarizes.
RANS: u_max/u_mean=1.1, sign for turbulent profil
LES: u_max/u_mean=2, sign for laminar profil
That's why I want to modify the data to initialize fluctuations for the veloicity and pressure datas in the LES.
I can modify the registers of the post-datas, but I don't know how to save them in the *.ccmp.
The simulations are solved with starcd 408. Does anyone know the command or anything that can help?
Old   August 13, 2009, 08:48
Aroon
Hello Thomas,
If you want to run LES on a smooth channel (which is periodic) even initialization will not help. This is not a problem with the software or your restart file. It is a commonly observed characteristic of solving turbulent flows using LES.
You need to trip the boundary layer to keep it turbulent. If you just initialize the flow is quickly going to laminarize unless it is in the highly turbulent regime.
Regards
Aroon
Old   August 24, 2009, 09:35
I made the LES of the channel like described in the tutorial 16 at the Star-CD Tutorial Guide. I initialised big vortices with a user-function and it seems to work. I get nice vortices and I hope the channel will stay turbulent by the following iteration steps ...
I couldn't find a solution for overwritting the *.ccmp-file, but it's actually not necessary.
Regards Thomas
modify volume fraction kevin chu FLUENT 7 May 20, 2011 03:35
How to modify the cfx5mkext.ccl yliu CFX 0 March 14, 2008 03:50
How to modify the bcdefi.f ?!!! tomosada Siemens 0 April 6, 2003 05:45
Modify Parameters During Iteration Alammar FLUENT 1 May 6, 2002 01:40
