Home > Forums > General Forums > CFD Freelancers
Urgent: Hydrocyclone
Old   March 4, 2014, 07:07
Exclamation Urgent: Hydrocyclone
Delhi
kaushik.iit is on a distinguished road
Hello!
I have simulated a hydrocyclone using Fluent (Ansys 13.0). I am using water as the primary phase and air as the secondary phase. I am using VoF and RSM models. Also I am activating DPM and using hypothetical discrete inert particles of density 2500 kg/m3. I am defining a surface injection originating from inlet.
After running the simulations, I am getting satisfactory velocity profiles (countours), pressure countours and phase distributions also. I am also able to visulaize the particle tracks. When I go to REPORTS > DISCRETE PHASE > SAMPLE, I get a .dpm file for the selected boundaries (i.e. inlet, overflow and underflow) for the selected injections.
I want to calculate the solid weight concentrations at the outlet boundaries i.e. (overflow and underflow). If I open the .dpm file in Microsoft Excel, I get following fields
( x y z u v w diameter t mass-flow mass frequency time name)
I request you to kindly tell me what does 't', 'frequency' and 'time' signify in the above? Also how to calculate the solid weight concentration at the outlet boundaries as I require these to calculate the frequency for frequency distribution?
kaushik.iit is offline   Reply With Quote
dpm in fluent, hydrocyclone problem, particle concentration
Hydrocyclone Al-Hashimi Main CFD Forum 0 July 21, 2012 04:17
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Hydrocyclone mesh Morteza2062 ANSYS Meshing & Geometry 1 July 15, 2010 05:43
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
